[postgis-devel] [PostGIS] #1676: Problem in converting from RT90(SRID=3021) to WGS84(SRID=4326)
trac at osgeo.org
Sat Mar 10 04:49:50 PST 2012
Reporter: arashamiri | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 1.4.3
Component: postgis | Version: 1.5.X
Keywords: |
I try with two different versions of postgreSQL and postGIS.
With the same SQL.
I want to convert coordinates in RT90(SRID=3021) to WGS84(SRID=4326)
Select * From ST_X(ST_Transform(ST_SetSRID(ST_Point(1335932, 6177809),
3021), 4326)) as long, ST_Y(ST_Transform(ST_SetSRID(ST_Point(1335932,
6177809), 3021), 4326)) as lat
First: PostgresSQL versione 8.4 , postgis-1.4.2
Result:
Long: 13.198086050257
Lat: 55.7017960558017
Second: PostgresSQL versione 9.1 , postgis-1.5.3
Result:
Long: 13.1954101954645
Lat: 55.7017121131652
The first seems wrong. The results are actually the lat,long in the
RT_1990(SRID=4124).
The second seems correct and the results are in WGS84(SRID=4326) which
they should be.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1676>
