[postgis-devel] PostGIS 2.0.0beta2 working for me...
Bborie Park dustymugs at gmail.com
Sun Mar 11 11:18:09 PDT 2012
Salvatore,
Can you attach /tmp/pgis_reg/dumper.err and /tmp/pgis_reg/loader.err
in a response to this email thread?
-bborie
On Sun, Mar 11, 2012 at 3:23 AM, Salvatore Larosa <lrssvtml at gmail.com> wrote:
> Unfortunately, I can't tell the same!
> Only topology and raster regression tests is right for me!
> In core I get 20 error:
> PostgreSQL 9.1.2 on x86_64-unknown-linux-gnu, compiled by gcc (Debian
> 4.6.2-12) 4.6.2, 64-bit
>  Postgis 2.0.0beta3SVN - r9475 - 2012-03-09 20:31:33
>   GEOS: 3.3.2-CAPI-1.7.2
>   PROJ: Rel. 4.7.1, 23 September 2009
> Running tests
>  loader/Point ........ failed (dumper geog test: dumping loaded
> table: /tmp/pgis_reg/dumper.err)
>  loader/PointM ... failed ( wkt test: running shp2pgsql
> output: /tmp/pgis_reg/loader.err)
>  loader/PointZ ... failed ( wkt test: running shp2pgsql
>  loader/MultiPoint ... failed ( wkt test: running shp2pgsql
>  loader/MultiPointM ... failed ( wkt test: running shp2pgsql
>  loader/MultiPointZ ... failed ( wkt test: running shp2pgsql
>  loader/Arc ... failed ( wkt test: running shp2pgsql
>  loader/ArcM ... failed ( wkt test: running shp2pgsql
>  loader/ArcZ ... failed ( wkt test: running shp2pgsql
>  loader/Polygon ... failed ( wkt test: running shp2pgsql
>  loader/PolygonM ... failed ( wkt test: running shp2pgsql
>  loader/PolygonZ ... failed ( wkt test: running shp2pgsql
>  loader/TSTPolygon ... failed ( wkt test: running shp2pgsql
>  loader/TSIPolygon ... failed ( wkt test: running shp2pgsql
>  loader/TSTIPolygon ... failed ( wkt test: running shp2pgsql
>  loader/PointWithSchema ..... ok
>  loader/NoTransPoint ........ failed (dumper wkb test: dumping loaded
>  loader/NotReallyMultiPoint ... failed ( wkt test: running shp2pgsql
>  loader/MultiToSinglePoint ... failed ( wkt test: running shp2pgsql
>  loader/ReprojectPts .... failed ( wkt test: running shp2pgsql
>  loader/ReprojectPtsGeog .... failed ( wkt test: running shp2pgsql
>  loader/Latin1 .... ok
>  binary .. ok
>  regress .. ok
>  regress_index .. ok
>  regress_index_nulls .. ok
>  lwgeom_regress .. ok
>  regress_lrs .. ok
>  removepoint .. ok
>  setpoint .. ok
>  simplify .. ok
>  snaptogrid .. ok
>  summary .. ok
>  affine .. ok
>  empty .. ok
>  measures .. ok
>  legacy .. ok
>  long_xact .. ok
>  ctors .. ok
>  sql-mm-serialize .. ok
>  sql-mm-circularstring .. ok
>  sql-mm-compoundcurve .. ok
>  sql-mm-curvepoly .. ok
>  sql-mm-general .. ok
>  sql-mm-multicurve .. ok
>  sql-mm-multisurface .. ok
>  polyhedralsurface .. ok
>  polygonize .. ok
>  postgis_type_name .. ok
>  out_geometry .. ok
>  out_geography .. ok
>  in_gml .. ok
>  in_kml .. ok
>  iscollection .. ok
>  regress_ogc .. ok
>  regress_ogc_cover .. ok
>  regress_ogc_prep .. ok
>  regress_bdpoly .. ok
>  regress_proj .. ok
>  regress_management .. ok
>  dump .. ok
>  dumppoints .. ok
>  wmsservers .. ok
>  wkt .. ok
>  wkb .. ok
>  tickets .. ok
>  typmod .. ok
>  remove_repeated_points .. ok
>  split .. ok
>  relate .. ok
>  bestsrid .. ok
>  concave_hull .. ok
>  hausdorff .. ok
>  regress_buffer_params .. ok
>  offsetcurve .. ok
>  relatematch .. ok
>  isvaliddetail .. ok
>  sharedpaths .. ok
>  snap .. ok
>  node .. ok
>  unaryunion .. ok
>  clean .. ok
>  relate_bnr .. ok
>  uninstall .. ok (3855)
> Run tests: 84
> Failed: 20
> make[1]: *** [check] Error 20
> make[1]: Leaving directory `/home/sam/pacchetti_gis/postgis-svn/regress'
> make: *** [check] Error 1
> Il giorno sab, 10/03/2012 alle 17.01 -0800, pcreso at pcreso.com ha
> scritto:
>> FWIW:
>> Built & installed OK on OpenSuse 12.1 64 bit:
>> PostgreSQL 9.1.1 on x86_64-suse-linux-gnu, compiled by gcc (SUSE
>> Linux) 4.6.2, 64-bit
>>  Postgis 2.0.0beta2 - r9428 - 2012-03-10 23:59:03
>> Passed all regression tests (make check) for core, raster & topology:
>> Works OK with imposm for OSM server:
>> imposm --read --write --optimize -d osm --overwrite-cache
>> newzealand.osm
>> General queries (so far) work OK.
>> Brent Wood
>> --- On Thu, 3/8/12, Paul Ramsey <pramsey at opengeo.org> wrote:
>>         From: Paul Ramsey <pramsey at opengeo.org>
>>         Subject: [postgis-devel] PostGIS 2.0.0beta2
>>         To: "PostGIS Users Discussion"
>>         <postgis-users at postgis.refractions.net>,
>>         postgis-devel at postgis.refractions.net
>>         Date: Thursday, March 8, 2012, 10:06 AM
>>         Hi All,
>>         PostGIS 2.0.0beta2:
>>         http://postgis.org/download/postgis-2.0.0beta2.tar.gz
>>         Current open tickets: http://trac.osgeo.org/postgis/report/22
>>         You'll note that the number of open tickets is getting close
>>         to zero.
>>         Like a rocket ship countdown, when we get to zero, we launch.
>>         But we need your help now, more than ever. Please try out
>>         PostGIS 2.0.
>>         Download it, build it, move your databases to it, make sure it
>>         works
>>         for you.
>>         Thanks!!!
>>         _______________________________________________
>>         postgis-devel mailing list
>>         http://postgis.refractions.net/mailman/listinfo/postgis-devel
