[postgis-devel] [PostGIS] #1678: [raster] GDAL_DATA dependency
PostGIS trac at osgeo.org
Mon Mar 12 08:30:41 PDT 2012
 Reporter:  robe    |       Owner:  pracine
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:  PostGIS 2.1.0
Component:  raster  |     Version:  trunk
 Keywords:          |
Comment(by dustymugs):
 Technically, this issue could be on any platform.  As GDAL's data
 directory is determined upon compilation, you can find out what your GDAL
 installation's path is
 gdal-config --datadir
 If the output of the above is NOT where your GDAL files are installed,
 you'll need to set GDAL_DATA.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1678#comment:2>
