[postgis-devel] [PostGIS] #1668: ST_AsText, ST_AsEWKT under Windows 64-bit PostGIS 64-bit is all screwy
PostGIS trac at osgeo.org
Mon Mar 12 12:12:32 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:  mingw64  |
Comment(by robe):
 hmm not sure.  Actually I think this issue may be patched in a later
 mingw64, so I'm setting up a newer one(I was kind of irritated about
 running 4.46 anyway instead of 4.5 something or other).  I followed
 Bborie's thread to a patch they put in but the patch is later than my
 20110516 build so I'm trying the 20111211 something or other sezero build.
 http://sourceforge.net/projects/mingw-w64/files/Toolchains%20targetting%20Win64/Personal%20Builds/
 (4.5 11/01/2011 one)
 In theory Paul -- you should be able to build on Mac.  They have a Darwin
 precompiled build.  i assume Darwin works on Mac?
 http://sourceforge.net/projects/mingw-w64/files/Toolchains%20targetting%20Win64/Automated%20Builds/
 anyrate I'll try your other patch in the wrong ticket.
 I've also got a ming32 one I'm setting up using the mingw64 chain but
 still in the middle of building the dependencies (have gdal and proj built
 ont aht so far.)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1668#comment:23>
