[postgis-devel] [PostGIS] #1668: ST_AsText, ST_AsEWKT under Windows 64-bit PostGIS 64-bit is all screwy
trac at osgeo.org
Tue Mar 13 09:08:58 PDT 2012
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: mingw64 |
Comment(by pramsey):
No, it's not hoping. You'll see it adds enough to fit maxlen into the
buffer. This code is behind all our AsText emitting and KML emitting, it's
not lightly used or tested. If for some unforseen reason it's just plain
impossible to add enough buffer or in fact there is a print error it
errors back to the caller, which seems perfectly reasonable.
Anyways, I will roll back the big patch shortly and Regina can try and
force MinGW to behave sanely.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1668#comment:35>
