[postgis-devel] [PostGIS] #1684: Option to disable comments building
PostGIS trac at osgeo.org
Wed Mar 14 03:48:50 PDT 2012
 Reporter:  robe         |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.1
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by robe):
 Yes they are but my feeling is that these should be packaged as part of
 the tar ball because they are the same regardless of OS. So I personally
 would be fine if extensions don't build if you disable comment building.
 Alternatively we could have the include comments part of extension be
 conditional on if you have xsltproc.  Whether the comments are present or
 not, it's still considered the same extension by postgresql since comments
 are an appendage of functions similar to how function specific variable
 settings are.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1684#comment:2>
