[postgis-devel] Removing JAR files from the repository (#1411)
Sandro Santilli
strk at keybit.net
Thu Mar 15 04:57:43 PDT 2012
On Thu, Mar 15, 2012 at 12:49:51PM +0100, MarĂa Arias de Reyna wrote:
> I guess I lack the time to do it. This first half of this year is
> going very hard. Probably I will fork it somewhere waiting for better
> times.
I think it's a good idea.
> Anyway: Maven is the best (and almost only painless) way to compile
> and build Java. It's like make or ant, but handling Java dependencies.
> All those jars you see downloading are just requirements to properly
> build the components.
> The ant task goes to the official repositories of Maven, download the
> environment, then the dependencies, run the build and then remove all
> the "trash" generated.
> If you take a closer look, the former way to build the java components
> was downloading manually certain jars, putting them on certain paths
> and then compiling the code with ant. I just changed it so maven does
> it automatically.
I'm more concerned about the .jar file in the repository:
java/pljava/postgis_pljava.jar
I don't have any major problem with those downloaded on the fly.
Is that needed ? Can we get rid of it ?
> The most obvious dependency needed is the postgresql java driver. This
> postgis driver is an extension of that driver. You cannot compile and
> build the postgis driver without having the base postgresql driver
> (another .jar).
Is PostGIS a dependency at all ? If not it may really make sense
to put the whole java part somewhere else.
I guess I may be mixing up java/pljava and java/jdbc ...
> I posted it here because it seems that I don't have permission to add
> a comment on the tracker itself.
I'll take a look. But this is really a better place for this.
--strk;
,------o-.
| __/ | Delivering high quality PostGIS 2.0 !
| / 2.0 | http://strk.keybit.net - http://vizzuality.com
`-o------'
