[postgis-devel] [PostGIS] #1690: Sort out ERROR: transform: couldn''t project point (180 -90 0): tolerance condition error (-20)
PostGIS trac at osgeo.org
Fri Mar 16 10:26:43 PDT 2012
  Reporter:  strk        |       Owner:  pramsey
      Type:  task        |      Status:  closed
  Priority:  medium      |   Milestone:  PostGIS 2.0.0
 Component:  postgis     |     Version:  trunk
Resolution:  worksforme  |    Keywords:
Changes (by strk):
  * status:  reopened => closed
  * resolution:  => worksforme
Comment:
 Ok, now I see that the commit replaced a DEBUG line with an ERROR line.
 Probably 1.5 has always given the ERROR so only a window in development
 mode temporarely changed that to give a wrong answer instead.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1690#comment:15>
