[postgis-devel] [PostGIS] #1694: PostGIS 2.0.0 does not build with clang
trac at osgeo.org
Mon Mar 19 10:02:32 PDT 2012
Reporter: vince | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by vince):
On my side, I get a bunch of these:
/usr/bin/clang -E -I../../postgis/ -I../../ -traditional-cpp
rtpostgis.sql.in.c | grep -v '^#' > rtpostgis.sql.in
rtpostgis.sql.in.c:276:83: error: empty character constant
AS $$ SELECT st_band($1, regexp_split_to_array(regexp_replace($2,
'[[:space:]]', '', 'g'), $3)::int[]) $$
rtpostgis.sql.in.c:3174:79: warning: missing terminating ' character
-- Check first if the
pixel intersects with the geometry. Often many won't.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1694#comment:2>
