[postgis-devel] [PostGIS] #1702: SetSRID, ST_Transform and geometry_columns in sync?
trac at osgeo.org
Thu Mar 22 00:31:07 PDT 2012
Reporter: darkblueb | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
-- the following sequence is an exposition on
-- SetSRID, Transform and the geometry_columns VIEW
-- Are the expectations of the relationships here clearly defined?
-- Is this the behavior desired in 2.0 Final ?
geom_test=# create table test1 (pkey integer PRIMARY KEY, the_geom
geometry);
NOTICE: CREATE TABLE / PRIMARY KEY will create implicit index
"test1_pkey" for table "test1"
CREATE TABLE
geom_test=# create index t_geom_idx on test1 using GIST(the_geom);
CREATE INDEX
geom_test=# \d
List of relations
Schema | Name | Type | Owner
public | geography_columns | view | dbb
public | geometry_columns | view | dbb
public | spatial_ref_sys | table | dbb
public | test1 | table | dbb
(4 rows)
-- INSERT a geometry with no intrinsic projection defined
geom_test=# insert into test1 VALUES (1,'POINT(1 1)');
INSERT 0 1
geom_test=# select * from geometry_columns ;
f_table_catalog | f_table_schema | f_table_name | f_geometry_column |
coord_dimension | srid | type
geom_test | public | test1 | the_geom |
2 | 0 | GEOMETRY
geom_test=# insert into test1 VALUES (2,st_geomfromEWKT('SRID=3310;POINT(1
1)'));
INSERT 0 1
-- geometry_columns VIEW shows no knowledge of the new POINT with
intrinsic SRID
2 | 0 | GEOMETRY
-- explicitly SetSRID on ALL POINTS
geom_test=# select st_setSRID(the_geom,3310) from test1;
st_setsrid
0101000020EE0C0000000000000000F03F000000000000F03F
(2 rows)
-- geometry_columns still shows no knowledge of intrinsic SRIDs after
SetSRID
2 | 0 | GEOMETRY
-- geometry binary unchanged, also
geom_test=# select st_asEWKT(the_geom) from test1;
st_asewkt
POINT(1 1)
SRID=3310;POINT(1 1)
(2 rows)
-- now add a new POINT with intrinsic SRID
geom_test=# insert into test1 VALUES (3,st_geomfromEWKT('SRID=3310;POINT(2
2)'));
INSERT 0 1
st_asewkt
POINT(1 1)
SRID=3310;POINT(2 2)
(3 rows)
-- transform binary geometry contents
geom_test=# update test1 set the_geom = st_transform(the_geom,4326) where
pkey = 3;
UPDATE 1
st_asewkt
POINT(1 1)
SRID=4326;POINT(-119.999977189465 38.0163834586186)
(3 rows)
-- no reflection in geometry_columns VIEW ?
2 | 0 | GEOMETRY
-- explitly call setSRID on top of instrinsic SRID on third POINT
geom_test=# select st_setSRID(the_geom,4326) from test1 where pkey = 3;
st_setsrid
0101000020E6100000EC5F53A0FFFF5DC02A7B69DA18024340
(1 row)
-- an attempt to transform all POINTs is caught on POINT 1 w/o instrinsic
SRID
geom_test=# update test1 set the_geom = st_transform(the_geom,4326);
ERROR: Input geometry has unknown (0) SRID
geom_test=# select pkey,st_asEWKT(the_geom) from test1;
pkey | st_asewkt
1 | POINT(1 1)
2 | SRID=3310;POINT(1 1)
3 | SRID=4326;POINT(-119.999977189465 38.0163834586186)
(3 rows)
-- geometry_columns VIEW does not reflect any change
2 | 0 | GEOMETRY
(1 row)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1702>
