[postgis-devel] [PostGIS] #1701: regress failures - can we not overwrite loader error file?
trac at osgeo.org
Thu Mar 22 13:28:43 PDT 2012
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: mingw64 |
Comment(by pramsey):
Run the ./run_test script directly so you can specify the precise test you
want to run. That's how I worked around this limitation. Can we close this
out or punt forward? It's not going to be a 2.0.0 fix.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1701#comment:1>
