[postgis-devel] [PostGIS] #1708: postgis_restore not converting ndims and srid constraints to st_...
trac at osgeo.org
Fri Mar 23 05:43:35 PDT 2012
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.1
Component: build/upgrade/install | Version: trunk
Keywords: |
Strk - my tables that use the deprecated ndims, srid constraints checks
won't load without me first installing legacy_minimal.sql
Attached is an example backup. I'm using ActiveState Perl64 if that makes
a difference.
my script looks like this:
set PGPORT=5434
set PGHOST=localhost
set PGUSER=postgres
set PGPASSWORD=something
set THEDB=test
set PGINSTALL=C:\Program Files\PostgreSQL\9.1
set PGBIN=%PGINSTALL%\bin\
set PGLIB=%PGINSTALL%\lib\
set PATH=%PATH%;%PGBIN%
perl utils/postgis_restore.pl "restore_test.backup" | psql %THEDB% 2>
errors_with_test.txt
The error file is empty.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1708>
