[postgis-devel] [PostGIS] #1711: ST_ModEdgeSplit robustness issue invalidates topology
PostGIS trac at osgeo.org
Fri Mar 23 15:11:05 PDT 2012
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  assigned
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Changes (by strk):
  * status:  new => assigned
Comment:
 Example: add this edge
 '01020000000400000000000000000034400000000000002440000000000000244000000000000024400000000000002240000000000000284000000000000024400000000000003440'
 Then split by this point '010100000000000000000022400000000000002840'
 Then validate the topology and you'll find node/endpoint mismatch.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1711#comment:1>
