[postgis-devel] [PostGIS] #1706: TopoGeo_AddPolygon not adding polygons
trac at osgeo.org
Fri Mar 23 15:57:25 PDT 2012
Reporter: pramsey | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Resolution: fixed | Keywords:
Changes (by strk):
* status: new => closed
* resolution: => fixed
Comment:
I'll call this fixed with r9540 (and r9539).
You will still get some spaghetti topology, but that's due to ST_Snap
being an inappropriate tool to deal with tolerances. See #1712 for one
(among a few) possible ways to improve it.
Generally speaking, try not to abuse tolerance. Should be fine as long as
no segment are shorter than the given tolerance. We're probably missing a
function to tell us about that (min/max segment length would be good stats
for vectors).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1706#comment:19>
