[postgis-devel] [PostGIS] #1707: Regress on topology running make check - r9529
trac at osgeo.org
Fri Mar 23 16:44:23 PDT 2012
Reporter: sindile | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: 2.0.x
Keywords: |
Comment(by strk):
First test is surprising (legacy_validate_expected):
+ERROR: function createtopology(unknown) does not exist at character 8
But regress.log says topology is added:
CREATE FUNCTION
addtosearchpath
topology has been added to end of database search_path
(1 row)
SET
COMMENT
@sindle : could you try this:
cd topology/test
../../regress/run_test --topology --nodrop -v regress/legacy_validate.sql
psql postgis_reg
> show search_path;
> select createtopology('tt1');
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1707#comment:5>
