[postgis-devel] Geometry type does not match column type
Salvatore Larosa
lrssvtml at gmail.com
Sun Mar 25 06:50:17 PDT 2012
Il giorno sab, 24/03/2012 alle 15.37 +0100, Salvatore Larosa ha scritto:
> Hi,
> I'm working with PostGIS tables and noticed some problems, but I can not
> tell if the problem is in QGIS or PostGIS!
> For this reason I am writing to both the mailing list.
> First issue:
> http://hub.qgis.org/issues/5109
> Second:
> If I use the SPIT plugin to import polygon features in PostGIS I get
> this:
> ##########CODE###############################################################
> Problema nell'inserimento di elementi dal file:
> /home/sam/test_topology/prov.shp
> Il database ha restituito un errore durante l'esecuzione di questa
> istruzione SQL:
> INSERT INTO
> "public"."prov"("provincia","cod_pro","sigla","cod_reg","sede","anno_volo","liv_utente","geom") VALUES ('Catanzaro','079','CZ','18',NULL,'.. (omesso l'SQL restante)
> L´errore era:
> ERROR: Geometry type (Polygon) does not match column type
> (MultiPolygon)
> ##########END###############################################################
first issue solved in commit 49456116 (thanks to Jürgen Fischer), it was
due to QGIS and likely, also the issue with SPIT plugin!
Cheers!
-SL
