[postgis-devel] [PostGIS] #1713: postgis extension cannot be made without raster
trac at osgeo.org
Mon Mar 26 03:43:54 PDT 2012
Reporter: mwtoews | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Resolution: wontfix | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => wontfix
Comment:
Believe it or not, we had long painful discussions about this and in the
end decided that we want raster to be part of the core postgis extension,
so building the postgis extension requires you build with raster and if
you don't want that you have to do it the old way without extensions.
http://www.postgis.org/pipermail/postgis-
devel/2012-January/thread.html#17158
topology is separate because well it is installed in a separate schema and
limitations of extensions don't allow extensions to go across schemas.
The main reason for this is it makes install easier for those who want
both raster and vector functionality. The only reason against it is it
adds a dependency on gdal.
In future releases of postgis, the gdal dependency may not be just limited
to raster though so keep that in mind. gdal brings in a whole wealth of
opportunities -- e.g the possibility of spatial foreign data wrappers that
piggy back on postgis geometry. Closer integration with our loaders etc.
Besides half the postgis dev team works on gdla anyway (you might become
victim of the borg too Mike :) )
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1713#comment:1>
