[postgis-devel] [PostGIS] #1697: Crash in GiST index with empty MultiPolygons
trac at osgeo.org
Wed Mar 28 01:09:51 PDT 2012
Reporter: realityexists | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by strk):
Tested, nice!
Looking forward to see the 2D index fixed too, so I can do:
explain select st_asewkt(g) from test where g ~= 'POINT EMPTY'::geometry;
And get all empty (or otherwise infinite) elements in the table!
More on the memset: is it needed at all ?
I see all uses of bbox_out protected by gidx_set_unknown already. Sounds
enough.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1697#comment:19>
