[postgis-devel] [PostGIS] #1728: measures regression test fails in 1.5 branch
trac at osgeo.org
Wed Mar 28 04:50:30 PDT 2012
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.4
Component: postgis | Version: 1.5.X
Keywords: |
Comment(by nicklas):
I have done some testing by putting notices in the function and I see how
p1 gets changed in a wrong way.
I have removed any modification of p1 and set p1.x and p1.y to 0.0 before
the iteration. Then it seems to work as expected both on 23 and 64 bit.
Do you think we should investigate ebtter the difference between 23 and 64
bit or should I just commit?
Little strange that it workwed at all before since P1 did never get any
value before the first iteration.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1728#comment:10>
