[postgis-devel] [PostGIS] #1728: measures regression test fails in 1.5 branch
PostGIS trac at osgeo.org
Wed Mar 28 06:52:49 PDT 2012
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 1.5.4
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
Comment(by nicklas):
 There was the same error all the time in 32-bit. I was testing a 9.0
 version but the fresh compile installed against 9.1.
 So, I think it is quite obvious what is happening and I think the attached
 patch fixes it. If there is no objections I will commit it and back port
 to 1.4
 But looking at the trunk I don't understand what is happening. It behaves
 correctly, but is at least hard to read.
 I will look at it and try to understand. If it is not clear to others what
 is happening I would like to rewrite it more along the line of 1.5.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1728#comment:14>
