[postgis-devel] [PostGIS] #1736: cunit failure on mingw64 rc1 - 1.#INF
PostGIS trac at osgeo.org
Thu Mar 29 06:49:52 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  trunk
 Keywords:           |
 I think there was a time when all my cunit tests used to pass, but it's
 possible it was failing on beta4 too since I think I had to cd to the
 other folders to tests the other tests.  So this might be cause of a
 change in my mingw64 environment. I think I was running gcc 4.4.7 or
 something when I was paying more attention and everything was passing.
 Suite: print_suite
   Test: test_lwprint_default_format ...passed
   Test: test_lwprint_format_orders ...passed
   Test: test_lwprint_optional_format ...passed
   Test: test_lwprint_oddball_formats ...passed
   Test: test_lwprint_bad_formats ...passed
 Suite: misc
   Test: test_misc_force_2d ...passed
   Test: test_misc_simplify ...passed
   Test: test_misc_count_vertices ...passed
   Test: test_misc_area ...passed
   Test: test_misc_wkb ...passed
 Suite: ptarray
   Test: test_ptarray_append_point ...passed
   Test: test_ptarray_append_ptarray ...passed
   Test: test_ptarray_locate_point ...passed
   Test: test_ptarray_isccw ...passed
   Test: test_ptarray_desegmentize ...passed
   Test: test_ptarray_insert_point ...passed
 Suite: PostGIS Computational Geometry Suite
   Test: test_lw_segment_side ...passed
   Test: test_lw_segment_intersects ...passed
   Test: test_lwline_crossing_short_lines ...passed
   Test: test_lwline_crossing_long_lines ...passed
   Test: test_lwline_crossing_bugs ...passed
   Test: test_lwpoint_set_ordinate ...passed
   Test: test_lwpoint_get_ordinate ...passed
   Test: test_point_interpolate ...passed
   Test: test_lwline_clip ...passed
   Test: test_lwline_clip_big ...passed
   Test: test_lwmline_clip ...passed
   Test: test_geohash_point ...passed
   Test: test_geohash_precision ...passed
   Test: test_geohash ...passed
   Test: test_isclosed ...passed
 Suite: PostGIS Measures Suite
   Test: test_mindistance2d_tolerance ...passed
   Test: test_rect_tree_contains_point ...passed
   Test: test_rect_tree_intersects_tree ...passed
   Test: test_lwgeom_segmentize2d ...passed
 Suite: node
   Test: test_lwgeom_node ...passed
 Suite: WKT Out Suite
   Test: test_wkt_out_point ...passed
   Test: test_wkt_out_linestring ...passed
   Test: test_wkt_out_polygon ...passed
   Test: test_wkt_out_multipoint ...passed
   Test: test_wkt_out_multilinestring ...passed
   Test: test_wkt_out_multipolygon ...passed
   Test: test_wkt_out_collection ...passed
   Test: test_wkt_out_circularstring ...passed
   Test: test_wkt_out_compoundcurve ...passed
   Test: test_wkt_out_curvpolygon ...passed
   Test: test_wkt_out_multicurve ...passed
   Test: test_wkt_out_multisurface ...passed
 Suite: WKT In Suite
   Test: test_wkt_in_point ...FAILED
     1. cu_in_wkt.c:71  - CU_ASSERT_STRING_EQUAL(r,"POINT(inf 0)")
   Test: test_wkt_in_linestring ...passed
   Test: test_wkt_in_polygon ...passed
   Test: test_wkt_in_multipoint ...passed
   Test: test_wkt_in_multilinestring ...passed
   Test: test_wkt_in_multipolygon ...passed
   Test: test_wkt_in_collection ...passed
   Test: test_wkt_in_circularstring ...passed
   Test: test_wkt_in_compoundcurve ...passed
   Test: test_wkt_in_curvpolygon ...passed
   Test: test_wkt_in_multicurve ...passed
   Test: test_wkt_in_multisurface ...passed
   Test: test_wkt_in_tin ...passed
   Test: test_wkt_in_polyhedralsurface ...passed
   Test: test_wkt_in_errlocation ...passed
 Suite: WKB Out Suite
   Test: test_wkb_out_point ...passed
   Test: test_wkb_out_linestring ...passed
   Test: test_wkb_out_polygon ...passed
   Test: test_wkb_out_multipoint ...passed
   Test: test_wkb_out_multilinestring ...passed
   Test: test_wkb_out_multipolygon ...passed
   Test: test_wkb_out_collection ...passed
   Test: test_wkb_out_circularstring ...passed
   Test: test_wkb_out_compoundcurve ...passed
   Test: test_wkb_out_curvpolygon ...passed
   Test: test_wkb_out_multicurve ...passed
   Test: test_wkb_out_multisurface ...passed
   Test: test_wkb_out_polyhedralsurface ...passed
 Suite: WKB In Suite
   Test: test_wkb_in_point ...passed
   Test: test_wkb_in_linestring ...passed
   Test: test_wkb_in_polygon ...passed
   Test: test_wkb_in_multipoint ...passed
   Test: test_wkb_in_multilinestring ...passed
   Test: test_wkb_in_multipolygon ...passed
   Test: test_wkb_in_collection ...passed
   Test: test_wkb_in_circularstring ...passed
   Test: test_wkb_in_compoundcurve ...passed
   Test: test_wkb_in_curvpolygon ...passed
   Test: test_wkb_in_multicurve ...passed
   Test: test_wkb_in_multisurface ...passed
   Test: test_wkb_in_malformed ...passed
 Suite: libgeom
   Test: test_typmod_macros ...passed
   Test: test_flags_macros ...passed
   Test: test_serialized_srid ...SRID value -3005 converted to the offici
 nown SRID value 0
 passed
   Test: test_gserialized_from_lwgeom_size ...passed
   Test: test_gbox_serialized_size ...passed
   Test: test_lwgeom_from_gserialized ...passed
   Test: test_lwgeom_count_vertices ...passed
   Test: test_on_gser_lwgeom_count_vertices ...passed
   Test: test_geometry_type_from_string ...passed
   Test: test_lwcollection_extract ...passed
   Test: test_lwgeom_free ...passed
   Test: test_lwgeom_flip_coordinates ...passed
   Test: test_f2d ...passed
   Test: test_lwgeom_clone ...passed
   Test: test_lwgeom_force_clockwise ...passed
   Test: test_lwgeom_calculate_gbox ...passed
   Test: test_lwgeom_is_empty ...passed
   Test: test_lwgeom_same ...passed
 Suite: split
   Test: test_lwline_split_by_point_to ...passed
   Test: test_lwgeom_split ...passed
 Suite: Geodetic Suite
   Test: test_signum ...passed
   Test: test_gbox_from_spherical_coordinates ...passed
   Test: test_gserialized_get_gbox_geocentric ...passed
   Test: test_clairaut ...passed
   Test: test_edge_intersection ...passed
   Test: test_edge_distance_to_point ...passed
   Test: test_edge_distance_to_edge ...passed
   Test: test_lwgeom_distance_sphere ...passed
   Test: test_lwgeom_check_geodetic ...passed
   Test: test_gserialized_from_lwgeom ...passed
   Test: test_spheroid_distance ...passed
   Test: test_spheroid_area ...passed
   Test: test_lwpoly_covers_point2d ...passed
   Test: test_ptarray_point_in_ring ...passed
 Suite: GEOS
   Test: test_geos_noop ...passed
 Suite: stringbuffer
   Test: test_stringbuffer_append ...passed
   Test: test_stringbuffer_aprintf ...passed
 Suite: surface
   Test: triangle_parse ...passed
   Test: tin_parse ...passed
   Test: polyhedralsurface_parse ...passed
   Test: tin_tgeom ...passed
   Test: psurface_tgeom ...passed
   Test: surface_dimension ...passed
   Test: surface_perimeter ...passed
 Suite: Homogenize Suite
   Test: test_coll_point ...passed
   Test: test_coll_line ...passed
   Test: test_coll_poly ...passed
   Test: test_coll_coll ...passed
   Test: test_geom ...passed
   Test: test_coll_curve ...passed
 Suite: out_gml
   Test: out_gml_test_precision ...passed
   Test: out_gml_test_srid ...passed
   Test: out_gml_test_dims ...passed
   Test: out_gml_test_geodetic ...passed
   Test: out_gml_test_geoms ...passed
   Test: out_gml_test_geoms_prefix ...passed
   Test: out_gml_test_geoms_nodims ...passed
   Test: out_gml2_extent ...passed
   Test: out_gml3_extent ...passed
 Suite: KML Out Suite
   Test: out_kml_test_precision ...passed
   Test: out_kml_test_dims ...passed
   Test: out_kml_test_geoms ...passed
   Test: out_kml_test_prefix ...passed
 Suite: GeoJson Out Suite
   Test: out_geojson_test_precision ...passed
   Test: out_geojson_test_dims ...passed
   Test: out_geojson_test_srid ...passed
   Test: out_geojson_test_bbox ...passed
   Test: out_geojson_test_geoms ...passed
 Suite: SVG Out Suite
   Test: out_svg_test_precision ...passed
   Test: out_svg_test_dims ...passed
   Test: out_svg_test_relative ...passed
   Test: out_svg_test_geoms ...passed
   Test: out_svg_test_srid ...passed
 Suite: X3D Out Suite
   Test: out_x3d3_test_precision ...passed
   Test: out_x3d3_test_geoms ...passed
 running gcc.exe (GCC) 4.5.4 20111030 (prerelease)
 no reason to stop the show for this one I don't think.  I'll upgrade and
 see if I still have same issue.
 If I put in a printf to see the difference I get:
 IN:  POINT(1e700 0)
 OUT: POINT(1.#INF 0)
 so I suppose it's probably a harmless failure
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1736>
