[postgis-devel] [PostGIS] #1716: SVN snapshot tarball lacks postgis_svn_revision.h
PostGIS trac at osgeo.org
Thu Mar 29 12:34:01 PDT 2012
  Reporter:  strk        |       Owner:  chodgson
      Type:  defect      |      Status:  closed
  Priority:  critical    |   Milestone:  Management 1.0
 Component:  management  |     Version:  trunk
Resolution:  fixed       |    Keywords:
Changes (by chodgson):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Hudson can't use make_dist.sh because (1) make_dist.sh doesn't really
 support SVN revisions (it still has the word "cvs" in several places) and
 (2) Hudson needs a special ./configure line that points to all the right
 versions of the pre-reqs. So I just copied the perl command that makes the
 postgis_svn_revision.h into the build script used by Hudson (it's
 otherwise quite similar to make_dist.sh, perhaps one rainy day I would
 consider consolidating them). The new snapshot has the svn revision header
 included.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1716#comment:5>
