[postgis-devel] Raster support in 2.0.0
Sandro Santilli
strk at keybit.net
Fri Mar 30 04:10:19 PDT 2012
Devrim: raster is critical in that in the postgis "EXTENSION"
(for PostgreSQL 9.1+) there'll be no separation between core
and raster.
--strk;
On Fri, Mar 30, 2012 at 02:08:35PM +0300, Devrim GÜNDÜZ wrote:
> Anyone?
> On Thu, 2012-03-01 at 20:02 +0100, Devrim GÜNDÜZ wrote:
> > Hi,
> > I began testing packaging PostGIS for Fedora/RHEL/Scientific
> > Linux/CentOS and others. So far it seems pretty fine, but I'm having
> > some issues with raster support.
> > To add raster support to PostGIS, I need to install gdal-devel package,
> > and the current gdal package in Fedora/EPEL repositories are not aware
> > of the new PostgreSQL RPM layout. I can make it aware, but then:
> > armadillo-devel is needed by gdal-1.9.0-1.f16.x86_64
> > cfitsio-devel is needed by gdal-1.9.0-1.f16.x86_64
> > CharLS-devel is needed by gdal-1.9.0-1.f16.x86_64
> > chrpath is needed by gdal-1.9.0-1.f16.x86_64
> > freexl-devel is needed by gdal-1.9.0-1.f16.x86_64
> > hdf-devel is needed by gdal-1.9.0-1.f16.x86_64
> > hdf-static is needed by gdal-1.9.0-1.f16.x86_64
> > hdf5-devel is needed by gdal-1.9.0-1.f16.x86_64
> > jasper-devel is needed by gdal-1.9.0-1.f16.x86_64
> > libgta-devel is needed by gdal-1.9.0-1.f16.x86_64
> > libspatialite-devel is needed by gdal-1.9.0-1.f16.x86_64
> > netcdf-devel is needed by gdal-1.9.0-1.f16.x86_64
> > libdap-devel is needed by gdal-1.9.0-1.f16.x86_64
> > librx-devel is needed by gdal-1.9.0-1.f16.x86_64
> > mysql-devel is needed by gdal-1.9.0-1.f16.x86_64
> > numpy is needed by gdal-1.9.0-1.f16.x86_64
> > ogdi-devel is needed by gdal-1.9.0-1.f16.x86_64
> > poppler-devel is needed by gdal-1.9.0-1.f16.x86_64
> > xerces-c-devel is needed by gdal-1.9.0-1.f16.x86_64
> > xz-devel is needed by gdal-1.9.0-1.f16.x86_64
> > and it means more build dependency to RPM buildfarm.
> > So, the question from the "non-GIS and just a packager guy" is: How
> > critical is raster support? Is it ok if I just ditch it out from the
> > spec file?
> > Regards,
> Devrim GÜNDÜZ
> Principal Systems Engineer @ EnterpriseDB: http://www.enterprisedb.com
> PostgreSQL Danışmanı/Consultant, Red Hat Certified Engineer
> Community: devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
> http://www.gunduz.org Twitter: http://twitter.com/devrimgunduz
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
,------o-.
| __/ | Delivering high quality PostGIS 2.0 !
| / 2.0 | http://strk.keybit.net - http://vizzuality.com
`-o------'
