[postgis-devel] [PostGIS] #1735: ST_MakeValid: exception on geometry
PostGIS trac at osgeo.org
Fri Mar 30 07:44:31 PDT 2012
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  assigned
 Priority:  medium     |   Milestone:  PostGIS 2.0.1
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by strk):
 Ok, the IntersectionMatrix was a false alarm, it's normal to have no
 boundary intersection for geometries w/out boundaries (due to
 Mod2BoundaryNodeRule), so back to the SymDifference bug: given two valid
 inputs, it raises the exception.
 What I was after is the fact that such input is coming from Polygonize
 (called by BuildArea)
 so should be pretty much all fully noded. In particular Polygonize returns
 3 polygons: one is the outer shell with 2 tiny holes, and the other 2 are
 the tiny holes on themselves.
 I've noticed that the outer shell with holes is considered invalid (self
 intersection) but the exterior ring itself is valid!
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1735#comment:14>
