[postgis-devel] [PostGIS] #1806: Extremely slow and CPU-intensive ST_MakeValid (ST_BuildArea) case
trac at osgeo.org
Tue May 8 02:52:35 PDT 2012
Reporter: strk | Owner: strk
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS 2.0.1
Component: postgis | Version: 2.0.x
Keywords: |
Changes (by strk):
* owner: pramsey => strk
* status: new => assigned
Comment:
Also memory usage keeps increasing.
Plan: rewrite BuildArea to avoid all those SymDifference calls and simply
skip polygons fully contained in other polygons (assuming those ones are
holes of the other).
Should work pretty good and fast...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1806#comment:4>
