[postgis-devel] [PostGIS] #1808: [raster] Raster importation creates gaps and corrupted data
trac at osgeo.org
Thu May 10 16:22:18 PDT 2012
Reporter: molgor | Owner: dustymugs
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS 2.0.1
Component: raster | Version: 2.0.x
Keywords: |
Changes (by dustymugs):
* status: new => assigned
Comment:
After examining other tiles in the same manner described before and
running a ST_SummaryStats on the table containing the original test raster
SELECT ST_SummaryStats('test_1808', 'rast');
The summary stats are as expected
(281410560,71759692800,255,0,255,255)
where the above is (count, sum, mean, std dev, min, max). This is exactly
as expected of the test raster.
Are you able to share your source raster?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1808#comment:13>
