[postgis-devel] [PostGIS] #1798: Performance issue with ST_Intersects(geometry, geometry)
trac at osgeo.org
Sun May 13 08:12:24 PDT 2012
#1798: Performance issue with ST_Intersects(geometry,geometry)
Reporter: nicklas | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.1
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by nicklas):
Ok, I have an example showing this issue
In the attached dump there is two tables. One with the two largest
polygons from the question in gis.stackexchange linked to above.
The two polygons have between 7000 and 9000 vertex-points each.
The other table is a point table with 100000 points spread over the box
from ST_Extent of the two polygons.
There is no indexes on the polygons.
So ther is two polygons with gid = 1 and gid = 2.
Running :
SELECT count(*)
FROM polygons , points
WHERE ST_Intersects(points.geom , polygons.geom) and polygons.gid in (1);
takes about 1600 ms.
The same with gid=2 takes about the same.
So to run the same with both polygons could be expected to take about
3-4000 ms,
But
SELECT count(*)
(1,2);
uses about 18000 ms.
If I put a gist-index on the points table the issue disappears. Then the
single polygon queries takes about 1200 ms each and the query with both
polygons uses about 2400ms.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1798#comment:5>
