[postgis-devel] [PostGIS] #1806: Extremely slow and CPU-intensive ST_MakeValid (ST_BuildArea) case
trac at osgeo.org
Sun May 13 12:23:47 PDT 2012
Reporter: strk | Owner: strk
Type: defect | Status: closed
Priority: high | Milestone: PostGIS 2.0.1
Component: postgis | Version: 2.0.x
Resolution: fixed | Keywords:
Comment(by hugoledoux):
I agree that keeping all the geometries can be useful, but we decided to
have an *automatic* method where the user presses one button and gets a
valid geometry. Our method is predictable since it can be explained in 3
simple steps, so the user knows what to expect.
I believe that if the user wants to manually edit a polygon (with a GUI
for instance), she can always go back to the original geometry.
Our design choice makes our algorithm very fast and scalable to very large
polygon, modifying it to return all the geometries would make it use more
memory and would slow it down...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1806#comment:22>
