[postgis-devel] [PostGIS] #1813: geometry_columns table fails to take into account the current schema search_path
PostGIS trac at osgeo.org
Mon May 14 08:54:28 PDT 2012
search_path
 Reporter:  chander  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
 The current geometry_columns table often lists tables that might not exist
 for a user (or might not be visible to them) because it fails to take into
 account the users current search path.
 I believe the SQL code for the view should have the following appended to
 it:
  and pg_catalog.pg_table_is_visible(c.oid)
 This would result in spatial_ref_sys only displaying information for
 tables that exist in the current search_path.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1813>
