[postgis-devel] [PostGIS] #1813: geometry_columns / geography_column table fails to take into account user permissions to table
trac at osgeo.org
Mon May 14 09:16:44 PDT 2012
Reporter: chander | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.1
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by chander):
Just to rephrase the previous comment of strk (without the double
negative):
I would like to find information about spatial tables that exist but are
not visible with my search_path. What's the rationale for that ? Are there
other examples in the standard catalogues ?
It seems to me that logically, the geometry_columns table should follow
the conventions used by other metadata commands (like \dt, etc.)
The /dt meta-command, or any of the "describe" type commands for example -
show you the tables that are visible to your current user. Various tools
get confused if you don't do this. A great example is pgsql2shp - which
breaks because it queries spatial_ref_sys using only the table name, and
expects the search_path to be respected (which would result, for example,
in a table not appearing twice in two different schemas.)
Also, tools like pgsql2shp, django (introspection), and others break if
two tables with the same name exist in a single database, because they
expect that a query of spatial_ref_sys will only show visible table
information.
Consider a tool that queries the geometry_columns table to get a list of
available tables with geometry data. Is it reasonable to present those
tables to the tool if the user won't be able to view them anyway (or
shouldn't be able to view them?)
The general expectation (when querying geometry_columns) of tools that
query this table, IMHO is that they will see tables that are visible to
the current logged_in user.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1813#comment:3>
