[postgis-devel] [PostGIS] #1820: Can't compile against 9.2 beta1
PostGIS trac at osgeo.org
Tue May 15 23:53:02 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by robe):
 That gets me more further and then breaks at:
 geometry_estimate.c: In function `geometry_gist_joinsel_2d':
 geometry_estimate.c:321: error: `Form_pg_class' undeclared (first use in
 this function)
 geometry_estimate.c:321: error: (Each undeclared identifier is reported
 only once
 geometry_estimate.c:321: error: for each function it appears in.)
 geometry_estimate.c:321: error: syntax error before "reltup"
 geometry_estimate.c:322: error: `reltup' undeclared (first use in this
 function)
 geometry_estimate.c:333: error: syntax error before "reltup"
 make[1]: *** [geometry_estimate.o] Error 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1820#comment:3>
