[postgis-devel] [PostGIS] #1824: Installation on windows 64 failed
PostGIS trac at osgeo.org
Wed May 16 10:56:11 PDT 2012
 Reporter:  pierrevandelaar        |       Owner:  robe
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.1
Component:  build/upgrade/install  |     Version:  2.0.x
 Keywords:                         |
Changes (by robe):
  * owner:  pramsey => robe
  * component:  postgis => build/upgrade/install
Comment:
 Pierre,
 the postgisgui folder is a self-contained set of libraries for running the
 shp2pgsql-gui loader/dumper.  It intentionally has some redundant files.
 Can you tell me which version of PostgreSQL you are running.  Do a
 SELECT version();
 Also where you got your installer from.  Someone posted a similar issue
 and that they were running with an installer they got from ESRI.
 http://postgis.refractions.net/pipermail/postgis-
 users/2012-May/034124.html
 did you try dependency walker as notied to see what else could be missing
 also which version of windows are you running on?
 Thanks,
 Regina
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1824#comment:1>
