[postgis-devel] [PostGIS] #1812: cunit failure on build area
trac at osgeo.org
Thu May 17 06:04:58 PDT 2012
Reporter: robe | Owner: strk
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 2.0.1
Component: postgis | Version: trunk
Resolution: | Keywords: mingw
Changes (by robe):
* status: closed => reopened
* resolution: fixed =>
Comment:
can you make the same fix for sql tests. I suspect its same issue:
regress_bdpoly_expected
-BuildArea|SRID=3;MULTIPOLYGON(((0 0 10,0 10 8,10 10 6,10 0 4,0 0 2),(2 2
5,4 2 4,4 4 3,2 4 2,2 2 1),(5 5 6,7 5 7,7 7 8,5 7 9,5 5 10)),((20 0 10,20
10 8,30 10 6,30 0 4,20 0 2),(22 2 5,24 2 4,24 4 3,22 4 2,22 2 1),(25 5
6,27 5 7,27 7 8,25 7 9,25 5 10)))
-BdMPolyFromText|SRID=3;MULTIPOLYGON(((0 0,0 10,10 10,10 0,0 0),(2 2,4 2,4
4,2 4,2 2),(5 5,7 5,7 7,5 7,5 5)),((20 0,20 10,30 10,30 0,20 0),(22 2,24
2,24 4,22 4,22 2),(25 5,27 5,27 7,25 7,25 5)))
+BuildArea|SRID=3;MULTIPOLYGON(((20 0 10,20 10 8,30 10 6,30 0 4,20 0
2),(22 2 5,24 2 4,24 4 3,22 4 2,22 2 1),(25 5 6,27 5 7,27 7 8,25 7 9,25 5
10)),((0 0 10,0 10 8,10 10 6,10 0 4,0 0 2),(2 2 5,4 2 4,4 4 3,2 4 2,2 2
1),(5 5 6,7 5 7,7 7 8,5 7 9,5 5 10)))
+BdMPolyFromText|SRID=3;MULTIPOLYGON(((20 0,20 10,30 10,30 0,20 0),(22
2,24 2,24 4,22 4,22 2),(25 5,27 5,27 7,25 7,25 5)),((0 0,0 10,10 10,10 0,0
0),(2 2,4 2,4 4,2 4,2 2),(5 5,7 5,7 7,5 7,5 5)))
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1812#comment:10>
