[postgis-devel] [PostGIS] #1828: Estimate returned by geography_gist_selectivity results in slow query plan for ST_DWithin
trac at osgeo.org
Thu May 17 06:47:13 PDT 2012
for ST_DWithin
Reporter: realityexists | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.1
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by realityexists):
Sure, in that case the query can be as simple as:
SELECT id
FROM _test_pos
WHERE ST_DWithin(pos, 'POINT(7 7)', 300000)
The table:
CREATE TABLE _test_pos (
id serial,
pos geography(Point,4326)
WITH data AS
SELECT generate_series(1, 20000)::float / 1000 AS x
INSERT INTO _test_pos(pos)
SELECT ST_MakePoint(x, x)::geography
FROM data;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1828#comment:8>
