[postgis-devel] [PostGIS] #1808: [raster] Raster importation creates gaps and corrupted data
trac at osgeo.org
Fri May 18 08:26:30 PDT 2012
Reporter: molgor | Owner: dustymugs
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS 2.0.1
Component: raster | Version: 2.0.x
Keywords: |
Comment(by dustymugs):
I updated the fill_1808.py script to populate the test raster with psuedo-
random floating point values between 0 and 100. I also wrote a pixel-for-
pixel comparison script to validate that what is loaded into PostGIS with
raster2pgsql matches that of the source test raster. The comparison
script requires the latest revision of postgis-trunk due to a bug I found
in 2.0.
Due to the massive size of the source test raster, I had my initial
comparisons only checking every N pixels (113 or some other prime number).
All those tests ran fine. I'm running a final test checking every pixel.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1808#comment:16>
