[postgis-devel] [PostGIS] #1830: pgsql2shp fix for "XInvalid endian flag value encountered" on PostgreSQL 9.2
trac at osgeo.org
Sun May 20 14:49:51 PDT 2012
9.2
Reporter: dfuhry2 | Owner: pramsey
Type: defect | Status: reopened
Priority: high | Milestone: PostGIS 2.0.1
Component: loader/dumper | Version: 2.0.x
Resolution: | Keywords:
Changes (by mcayland):
* priority: medium => high
* resolution: fixed =>
* status: closed => reopened
* component: postgis => loader/dumper
Comment:
NAK. This patch is broken and should be reverted because:
1) The default switch from 'escape' to 'hex' took place in PostgreSQL 9.0,
so I'm not yet convinced that your diagnosis pointing at PostgreSQL 9.2 is
correct
2) You've now broken dumping from older (< 9.0) PostgreSQL servers during
a micro/patch revision
The symptoms suggest that your pgsql2shp client binary is linked against a
pre-9.0 libpq somewhere else on your system, which is why libpq can't
successfully interpret the 'hex' encoding being received from the server
(we use libpq's internal PQescapeBytea() function rather than doing it
ourselves).
In short, we need a better investigation of the problem and a revised
patch to suit.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1830#comment:2>
