[postgis-devel] git mirror
Sandro Santilli
strk at keybit.net
Tue May 22 05:36:50 PDT 2012
I've been re-cloning the PostGIS SVN repository into a GIT one
while making sure to retain full authors information. You may
have noticed the result of that being the authors.git file.
Interesting enough, the GIT commit identifiers differ from the
ones I had w/out specifying an author file. This means that
differently "cloned" repositories won't have common roots.
So, in order to match, the svn cloning procedure is as follows:
SVNROOT=http://svn.osgeo.org/postgis
wget ${SVNROOT}/trunk/authors.git
git svn clone --authors-file=authors.git --stdlayout ${SVNROOT}/
For a quick verification, output of
git show --summary be40e05 | grep git-svn-id | awk '{print $2}'
should give you:
http://svn.osgeo.org/postgis/trunk@9773
After that, you might want to setup all branches:
git branch -r | grep -v `git remote` | grep -v tags | sed 's/ *//' |
while read; do git branch "svn-${REPLY}" $REPLY; done
And all tags:
git branch -r | grep tags | sed 's/ *tags\///' |
while read; do git tag "${REPLY}" tags/$REPLY; done
The branches and tags operation may need to be performed again whenever
things change on the SVN side, changes which you would get with:
git svn fetch
I pushed the result of the above processing to a github repository:
https://github.com/postgis/postgis
And will setup an hourly cronjob to keep it updated.
Cloning again from SVN will take time (possibly hours).
Cloning from the github mirror is way faster, but setting a link
back to SVN for direct commits is trickier:
git clone git://github.com/postgis/postgis.git
cd postgis
git svn init --stdlayout http://svn.osgeo.org/postgis
cp authors.git ..
git config svn.authorsfile ../authors.git
# Link branches to SVN
git show-ref | grep remotes | grep svn | sed 's/.*svn-//' |
while read; do
git update-ref refs/remotes/${REPLY} refs/remotes/origin/svn-${REPLY};
done
# Link tags to SVN
git tag -l |
while read; do
git update-ref refs/remotes/tags/${REPLY} ${REPLY};
done
# Rebuild revision maps
git svn fetch
I'm working on the procedure to keep the mirror in sync.
Meanwhile maybe we want to drop some of the automatically created branches:
svn-0.9
svn-1.0
svn-1.1
svn-1.3
svn-1.4
svn-1.5
svn-2.0
svn-gSoC2007
svn-gSoC2007_raster
svn-pgis_0_9_0
svn-pgis_1_0
svn-refractions
svn-trunk
In particular, it looks like the gSoC branches are spikes
in SVN, rather than proper branches, and the _current_ SVN
seems to only know about the numbered branches:
http://svn.osgeo.org/postgis/branches/
I guess I can drop the unknown ones ?
--strk;
,------o-.
| __/ | Delivering high quality PostGIS 2.0 !
| / 2.0 | http://strk.keybit.net - http://vizzuality.com
`-o------'
