[postgis-devel] [PostGIS] #1841: ST_Distance on PostGIS 2.0 is prohibitively slow
trac at osgeo.org
Wed May 23 11:41:03 PDT 2012
Reporter: andrewxhill | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: 2.0.x
Keywords: st_distance, speed |
Comment(by strk):
Syntetized dataset: http://strk.keybit.net/tmp/slowdist.zip
avg/max/min points: 416.5136436597110754 | 582 | 10
Takes over 6 minutes to run this:
select sum(d) from ( select a.a as g1, b.a as g2, st_distance(a.g, b.g) as
d from a join a b on a.a<b.a ) as foo;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1841#comment:1>
