[postgis-devel] [PostGIS] #1839: [raster] raster2pgsql is unable to handle TIFF subdatasets
trac at osgeo.org
Wed May 23 13:45:55 PDT 2012
Reporter: turbothomas | Owner: dustymugs
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.1
Component: raster | Version: 2.0.x
Keywords: raster2pgsql, TIFF, subdataset, history |
Changes (by rouault):
* cc: rouault (added)
Comment:
If I'm allowed to comment a bit about the code, I don't think that the
approach taken in isSubDataset() is so great in term of exaustiveness and
maintainability. I'm not sure you have captured all the GDAL drivers that
support subdatasets (actually I know some others, and the list can
potentially grow with newer GDAL version), and it should not be the job of
PostGIS to know their syntax. I'd recommand using GDALIdentify() and if it
succeeds, then it's a GDAL dataset or subdataset.
Another related remark about the code around line 2537 that uses fopen()
to test if it is a raster, that is based on fopen(). GDAL supports opening
files on exotic filesystems like /vsizip/ , /vsicurl/ or even things that
are not files, like a PostgisRaster dataset, or a GeoRaster dataset...
Same as above, GDALIdentify() would be better.
So all in all I think you could just drop isSubDataset() and use
GDALIdentify().
(Sorry if I'm perhaps misunderstanding the code. My comments are only
based on code reading.)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1839#comment:8>
