[postgis-devel] [PostGIS] #1842: WHERE ST_Intersects causes VM to balloon
trac at osgeo.org
Wed May 23 18:08:20 PDT 2012
Reporter: darkblueb | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS GEOS
Component: postgis | Version: 1.5.X
Keywords: |
a particular query causes allocations of VM that eventually cause the
process to be killed, before completion. The same query on the same data
on another host does not show this behavior. Test query, sample data and
machine descriptions are enclosed.
One workaround is to use
... WHERE a.wkb_geometry && b.wkb_geometry;
instead, but that causes NULL and POINT results along with the desired
intersection results to be generated. Another workaround may be to
setting RLIMIT_VMEM for Postgres under Linux/POSIX ?
CREATE TABLE lt_grid_intersect_marin_intersmethod
as
SELECT
ST_Intersection(g.wkb_geometry, l.wkb_geometry) as wkb_geometry,
id_grid,
landtype,
fmmp_class
FROM grid150m_marin_subset as g, lt_marin_subset as l
WHERE ST_Intersects(g.wkb_geometry, l.wkb_geometry);
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1842>
