[postgis-devel] [PostGIS] #1839: [raster] raster2pgsql is unable to handle TIFF subdatasets
trac at osgeo.org
Wed May 30 22:43:21 PDT 2012
Reporter: turbothomas | Owner: dustymugs
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.1
Component: raster | Version: 2.0.x
Keywords: raster2pgsql, TIFF, subdataset, history |
Comment(by dustymugs):
Well, that was fun. PostGIS Raster has a maximum permitted width/height
size of 65535 x 65535. Unfortunately, there was no obvious error message
when you attempt to exceed that limit. I was testing your Eiche*.tif file
and hit it using...
raster2pgsql GTIFF_DIR:2:Eiche_1_1_2011_08_17_768_M2_3D_5mm.tif blabla
So, the lesson learned is that I need to add an explicit error message
when someone hits this maximum and you really shouldn't call it the way I
did above. Please tile your raster to be at most 65535 x 65535.
And before anyone asks why the maximum width and height is set to 65535 x
65535, imagine the size of the following...
65535 width * 65535 height * 8 bytes per pixel (64BF) = 34358689800 bytes
(not counting overhead)
That would be a very monstrous number considering the maximum size
permitted in a single field of PostgreSQL is 1 GB
(http://www.postgresql.org/about/) .
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1839#comment:24>
