[postgis-devel] [PostGIS] #1850: upgrade scripts for postgis 2.0 and 2.1
PostGIS trac at osgeo.org
Thu May 31 07:46:47 PDT 2012
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.1.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
 the upgrade script for PostGIS 2.0 is mislabled (should be 2.0-2.1 or some
 such thing) and we have no PostGIS 2.1 minor upgrade scripts.
 Extensions we need to break out too.
 I propose we start with a clean slate for 2.1 minor script -- if someone
 is running 2.1 there is no need for all that drop alter etc. stuff that
 might get in the way if they have views etc built on those. Just adds
 baggage.  Not sure the easiest way to do that without creating a
 maintenance nightmare.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1850>
