[postgis-devel] [PostGIS] #2082: Add index on edge_data.{start, end}_node
trac at osgeo.org
Sun Nov 4 12:47:45 PST 2012
#2082: Add index on edge_data.{start,end}_node
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: topology | Version: 2.0.x
Keywords: |
Since start_node and end_node are foreign keys to node.node_id, removing
isolated nodes becomes a very expensive operation when those fields are
not indexed as they require a sequencial scan on the whole edges table for
each DELETE.
I've been waiting more than 30 minutes before killing a DELETE query aimed
at cleaning up a topology...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2082>
