[postgis-devel] [PostGIS] #1999: Crash on LINESTRING with one point
trac at osgeo.org
Wed Nov 7 07:19:41 PST 2012
Reporter: realityexists | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
If it is a windows 64-bit issue, it might be a result of improvements
they've made in mingw64 compile between 9.1 and 9.2
For example in 9.2 I can compile for both 32-bit and 64-bit under mingw64
chain, but 9.1 I can compile only the 64-bit chain.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1999#comment:5>
