[postgis-devel] [PostGIS] #2088: can we get rid of the xmllint check
trac at osgeo.org
Thu Nov 8 00:50:27 PST 2012
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: build/upgrade/install | Version: trunk
Keywords: |
Comment(by robe):
I think we should move it. The only reason xml needs to be used for
regular checking is to generate the comments and then I would say we don't
care about xmllint just care if the comments are installable or not.
We don't use make check for building docs.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2088#comment:3>
