[postgis-devel] [PostGIS] #2091: Ability to see jenkins duration over time
PostGIS trac at osgeo.org
Sat Nov 10 22:31:29 PST 2012
 Reporter:  robe         |       Owner:  robe
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  Management 2.0
Component:  buildbots    |     Version:
 Keywords:               |
 Regarding this:
 http://lists.osgeo.org/pipermail/postgis-devel/2012-November/022557.html
 I think there are some report plugins we can install to graph this
 information.  The timing is there in the build logs reports and debbie
 seems to be doing on average about 3.5-4 minutes per regress run.
 If you are measuring from when you see a success note, the timing is
 longer I think because she used to just test 9.1 and then we slowly added
 on 9.2,9.3 and 9.0. So now she's doing 4 regresses per PostGIS commit for
 the 2.1 branch.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2091>
