[postgis-devel] [PostGIS] #1828: Estimate returned by geography_gist_selectivity results in slow query plan for ST_DWithin
trac at osgeo.org
Thu Nov 22 22:15:29 PST 2012
for ST_DWithin
Reporter: realityexists | Owner: mcayland
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.0.2
Component: postgis | Version: 2.0.x
Resolution: | Keywords:
Comment(by pramsey):
I made a lot of careless mistakes in that sequence, but the final problem
ended up being quite subtle. r10731 I didn't fix it, I just reverted it.
It's tricky and sensitive. The geodetic bounding box of a point, when
converted to float and stored in the gserialized is slightly larger than a
point. For a one-entry table, that means the histogram is not just a
single box, but something bigger. Math explodes, unpleasantness ensues.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1828#comment:57>
