[postgis-devel] [PostGIS] #1764: [raster] overviews not marked as same alignment though main table is
trac at osgeo.org
Mon Nov 26 11:29:24 PST 2012
Reporter: robe | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: raster | Version: trunk
Keywords: |
Changes (by dustymugs):
* status: assigned => new
* version: 2.0.x => trunk
Comment:
I was thinking of a possible solution to this issue...
1. before doing anything to the set of import rasters, see if the set are
aligned
2. if set of input rasters aligned, overviews are guaranteed to be aligned
As it looks like raster2pgsql may need to move away from using VRTs for
overviews, this would be an appropriate change to make at the same time.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1764#comment:16>
