[postgis-devel] [PostGIS] #1824: Installation on windows 64 failed
PostGIS trac at osgeo.org
Wed Nov 28 04:56:34 PST 2012
  Reporter:  pierrevandelaar        |       Owner:  robe
      Type:  defect                 |      Status:  closed
  Priority:  medium                 |   Milestone:  PostGIS 2.0.1
 Component:  build/upgrade/install  |     Version:  2.0.x
Resolution:  fixed                  |    Keywords:
Comment(by tastle):
 Hi all,
 I just installed Postgres 9.1.6 Windows x64.  Then I installed PostGIS
 2.0.1 for pg 91 x64 and I get the same error as above.  "ERROR:  could not
 load library "C:/Program Files/PostgreSQL/9.1/lib/postgis-2.0.dll": %1 is
 not a valid Win32 application."
 I didn't quite follow the resolution in the steps above.  How do I go
 about this?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1824#comment:9>
