[postgis-devel] [PostGIS] #2114: tiger_2010 loader unzip breaks on some states
PostGIS trac at osgeo.org
Wed Nov 28 09:21:51 PST 2012
 Reporter:  channelzero     |       Owner:  robe
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.2
Component:  tiger geocoder  |     Version:  2.0.x
 Keywords:                  |
 The tiger2010 loader script has the following lines for unzipping the
 files downloaded by the wget command that precedes it.
 for z in *.zip; do $UNZIPTOOL -o -d $TMPDIR $z; done
 for z in */*.zip; do $UNZIPTOOL -o -d $TMPDIR $z; done
 This doesn't work for Pennsylvania or New Hampshire as both States wget
 command results in subdirectories with the zipped files.  I used the
 stanza below to fix the issue for New Hampshire and Pennsylvania and
 commented out the lines above
 find $STATEDIR/ -name "*.zip" | while read z;  do $UNZIPTOOL -o -d $TMPDIR
 $z; done
 It works for me on the rest of the States. But, I don't know if there are
 other consequences that I cannot see.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2114>
